Memory stick
    Other Hardware Memory stick
    hi all
    Just a quick question for all of you, I've just tried to copy a film to a memory stick 8gb it seemed to copy fine, but when I put it in my DVD player it doesn't play just wondering if anyone could help with this.
    :) never look down on anyone unless you're looking down at them to help them up:)
    Your player doesn't seem to like either the used codec, file format, file name.
    And are you sure your DVD player plays video files from USB?
    人生は贈り物であり、完全な喜びを経験する必要があります
      hi yes I'm pretty sure it does play videos through the USB port. When I look at the settings on my DVD player it says music photos or video. Then I get a screen up saying main movie which is fine but when I press play nothing happens.
        The DVD players I have with USB ports will NOT play DVD-Video (VIDEO_TS, IFO+VOB) that is stored on the USB drive.
          I've never tried, but if you've tried VLC and /or Media Player Classic I'd say you out of luck.
            Hey pard, didn't spot you in time
              Think you for your advice, I think I've found the problem. The DVD player says it plays MPEG movies, but when I looked more closely at the instructions it says it will not recognize a memory stick more than 4gb. And I've been trying to do this on a 8 gb memory stick so I think that's my problem. Once again thank you for your advice and time. ps I wish this snow would go away I'm supposed to be in Spain today with family
                No kidding, strange weather.
                I'm in Maine and no snow and it's Dec. !!!
                One of my colleagues, who is from greater London, can't believe it.
                Hope it lets up and you get to spend time with your loved ones...SOON !
                  hi let's hope so, I've been told to go to gatwick airport tomorrow , to be there by 11 a.m. but there is no guarantee of a flight, so fingers crossed.
                    It could be the format of the USB drive/stick itself ie FAT32, NTFS etc... have to look in your manual.
                    "You've got a hole in your soul if you don't dig the Blues"
                    Keith Richards ~ "If You Want The Last Laugh........Join The Rolling Stones"
                    Click to join forum.dvdfab.com
                      hi
                      I looked in the manual, and it just says MPEG movie. I checked my USB stick and it says fat 32 Hope this helps.
                        A USB memory stick can be easily formatted from Fat32 to NTFS .
                        FAQ - How do I format a USB Flash Drive to NTFS file system? To enable NTFS on your USB Flash Drive drive
                          I think you may find the problem is that the player software that reads the USB stick can't read IFO files. You can try converting to VOB/MPG using VOB Passthrough in DVD Ripper. The FAT32 problem will continue to be a problem however (originals >4GB=SOL).
                            I think Bob nailed it. I have a PS3 that will play VOB passthrough from the USB drive but won’t play the VIDEO_TS folder. It will only see a FAT32 formatted drive which has the 4GB-1 byte file size limit. You can make a VOB passthrough and change the file extension from .VOB to .MPG if needed, but probably can’t exceed the 4GB limit unless your player recognizes an NTFS formatted thumb drive.
                              ya and thanks for typing all that out for me. I was busy at the time and thought most of that info would be in the manual
