DVDFab Common Settings...
    I was wondering if someone could help me...
    I have recently had to uninstall and reinstall the latest version of DVDFab,
    and of course, forgot to write down all the modified settings for the software.
    I remember reading a post by someone (can't remember who) who had some great tips for modifying the common settings... Tips such as:
    Setting PathPlayer to scan BOV's:
    Setting the top slider to 480 seconds, and the bottom slider to 5...
    He also had many other great tips which I have found to be very useful!
    Any help in pointing me to this post would be greatly appreciated!
    Thanks in advance...
    rggauld
    I am not sure if you could find that post you will have to search the forum but, it was Signals the administrator who had suggested those settings
    CBR929
      Here are the setting I use, from top to bottom:
      General
      UNcheck memorize user interface options
      UNcheck autoplay handler (I have autoplay turned off in windows)
      UNcheck on-the-fly decrypter test (I know what I have running)
      UNcheck check for new verion automatically*
      UNcheck Create files in subfolders of output directory
      Customize UI
      UNcheck both boxes
      A/V Codec
      varies with content and your video card (set to all software and disable Lightning Recoding for crash problems*)
      Preview
      UNcheck both boxes under Playback*
      DirectShow decoder, DXVA depends on your video card (I have it disabled)
      Filters: DVDFab video and audio
      Internal decoder for crash problems*
      Sound
      your choice
      Network
      varies with your network connection, I have it set for Direct Connection
      Diagnosis
      enable all logs, check Run Report program
      DVD/Blu-ray->
      Read
      set mode to SPTI (unless you have Win98 or other odd/outdated OS)
      Error control: select Ask Retry/Ignore/Abort
      Cache Control: Enable, disable it if you get read errors or crashes or have limited system resources*
      Blu-ray: set to Internal
      UNcheck Do not eject Source when finished copying
      Write (varies with burn engine)
      Burning engine: ImgBurn
      DVD
      Write speed 8X (varies with media and burner)
      DVD-5 size: 4464 MB (only with Verbatim or TY media, 4300 otherwise)
      DVD-9 size: 8152 MB (Verbatim only, otherwise 8000)
      SAO Write type
      Blu-ray
      Write speed: (varies with media and burner)
      BD-25 size: 23700
      BD-50 size: 43700
      UNcheck all boxes except Set booktype to DVD-ROM if your drive supports it and you use +R media
      Protection->
      DVD
      Check all boxes EXCEPT UNcheck Remove layer break if using ImgBurn
      Blu-ray
      Check all boxes
      PathPlayer
      Select Always Enable
      set Scan cells (top) slider to 480 seconds or higher
      set VOBU slider to 10 or lower
      Note: these are what I call "deep scan" settings and will take longer; use the defaults (300/30) if it's too slow for you.
      Check the Check for multiple sets of BOVs box
      Streams
      will vary with your location and preferences
      I have it set for English audio, Dolby Digital, select first track from multiples; subpicture set for preselect English, and Do not preselect any track if there is no English
      DVD Copy
      your preferences
      mine are set for DVD-9 and DVD Folder, dvdid.xml box unchecked.
      Split and Customize set for Black screen and Disc 1.
      Blu-ray Copy
      Default size BD50
      UNcheck full scan and HD Audio boxes
      BD9/BD5 button set for software player friendly (lower button)
      Encoding set for fast speed, Normal Quality
      DVD/Blu-ray Ripper->
      Convert
      Check Enable Turbo CPU (varies with your CPU)
      Memory selector to Auto (varies with your resources)
      1CD= 700 MB
      Check Crop Automatically
      Default framerate set to specified in profile
      Default Audio set to specified in profile
      Audio downmix set to Stereo (depends on your player)
      Output
      your preference, I have it set to <Volume>.<Video Codec> for DVD and Blu-ray source and <SourceFileName>.<VideoCodec> for Files source
      File Transfer
      UNcheck box
      *use these settings if you have crash or startup problems ("low stress" mode)
