Is there any type of media disc that I should avoid using?
Any recommendations on medial to use
Verbatim with AZO logo on wrapper or Taiyo Yuden which are considered the best but rather expensive and only available online at online stores such as blankmedia.ca and others. Check this thread out for other deals and more suggestions for blank media http://forum.dvdfab.com/showthread.php?t=4175
newegg.com deals
Verbatim 4.7GB 16X DVD+R 100 Packs Spindle Disc Model 95098 $16.99 with free shipping
Verbatim 4.7GB 16X DVD-R 100 Packs Cake Box Disc Model 95102 $19.99 with free shippingLast edited by AGJ; 12-19-2010, 11:47 PM.
Originally posted by W. Carl View PostThanks for the reply. I am on a limited budget and not working full time so i have to watch what I spend. Currently TDK and Memorex is on sale in the area I live. Would you recommend either one of these or not. Thanks Carl
The problems with the cheaper disc's is that sure, you may get them to burn your movies but 6-12 months down the road they may not work any more and you will be burning them again
CBR929
Sorry AGJ did not see you
Originally posted by AGJ View PostNope those are not reliable but check out newegg for those verbatim as they pretty cheap with free shipping. newegg always has sales like that for verbatim and the DVD+R on sale $16.99 for a 100 spindle pack with free shipping is a deal of a lifetimeLast edited by CBR929; 12-20-2010, 02:41 AM.Even if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
Using Verbatim
Thanks for help in refering what DVD's to use. last week I bought a pack of Verbatim DVD-R 100 pack 47.; 16x; 120 min on a spindle and the label says Life Series at Office Max and then today I bought same type, but label does not say life series and they were not on a spindle just wrapped bought at Fry's Electronics. Did I purchase the right ones, because the coloring of the labels are not the same as those sold at Newegg.com Thanks
Last edited by CBR929; 12-27-2010, 09:37 PM.Even if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
Yeah, the life series verbs are made by CMC Magnetics, which is basically Memorex, so I would do as CBR suggests and get the AZO dye verbs. They will usually tell you on the outside of the package where the discs were made also. I believe the Made In Singapore are the best you can get, followed by Taiwan, then UAE, then India are the worst but those are still better than the CMC life series for sure.SPECS
Verbatiums DVD's
Thanks for the info on purchasing Verbatium DVD's with AZO. Have started using the disc's. I would like to transfer previous discs that i have made to the Verbatiums, but the copy process fails. Could this be because I copied all those movies on cheap discs. Once again thanks for all your help! Carl
If the discs play without glitches, you should be able to read and copy them. You should post any error codes and the internal and burn logs from DVDFab.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
