couple questions
    couple questions
    I just purchased a HP Mediasmart server to host all if my dvd's/music/pictures. I'm looking for the best solution for ripping my DVD's and Blu-Ray Dvd's to the server to then stream to my xbox, put on my iphone, or play on my ipad. I believe that DVDFab is that product. I downloaded the Blu-ray ripper and tested it on Iron Man 2. Here's my questions.
    1. If I purchase the full version, does it have the "DVD FAB" icon at the beginning of all the movies as well, or is that just something built into the trial version?
    2. I'm not stupid when it comes to computers, but that doesn't mean I'm knowledgeable in this department. When I'm trying to rip, do I need to setup a "Queue" for every device type that I want to use? currently what I did for my test was rip to AVI. I didn't setup any queue's. When I mapped to the server from the xbox, I found my folder with the movie and it played fine. But when I went to the server and looked at the file, it was a WMA file. WHile this is great for the xbox or computers, it sucks for the ipad/iphones. What did I do wrong?
    3. Looking at file sizes, I have 8 TB of space to work with, so I'm not hurting for space, but don't want to just throw caution to the wind. If I build up queue's for all the device types, does it creat a separate file for each device type? TO me this seems incredibly stupid as I don't need to have 20 gigs used up on each blu-ray movie.
    Most of these answers will be done when the movie gets done ripping again, but I figured I'd ask here instead of waiting 9 hours to find out.
    The watermark logo is not present on the registered version.
    I'm not sure I understand your expectations of having one file to play on all your devices. This is not possible if they don't have a file format in common. Also impractical from the standpoint that you don't need the same size file (same resolution) to play on a small-screen device that you would want for a large screen PC or TV.
      I see. The main devices are the Xbox360 and the Ipad. THe iphone option I don't care about. All of these devices though play MP4 format. Is there a way to set Bluray Ripper to MP4?
        I was not aware the XBox played MP4s (I don't have one). But yes, you can make MP4s with Blu-ray Ripper. To see all of the MP4 options, click on "More" in the Blu-ray Ripper navigation pane on the left, then select the MP4 logo. You can choose many types including a generic Main Level one that should play in almost anything.
          I do not have an MP4 option. I have
          Blu-ray ripper
          Xbox360
          PS3
          Ipod / Iphone
          to AVI
          More
          > to MKV
          > iPad
          >Audio
          >M2TS
          I've reinstalled the app 3 times now to ensure I didn't miss something. Only place I see MP4 is under Video Converter.
            check out attachment
              Nope. nothing like that
                I figured it out. Under the customization UI area, it was selected to not show. I moved it and it shows now.
                  I forgot about that setting and glad you found it
