I used DVDFab for the first time and was pleased with the results: the picture was in Letterbox format (bars across top and bottom - only. Then, flush with success, tried another DVD. This time, the picture was in Letterbox format BUT it had black bars on all sides. Since I could not have fifddled with settings, is there an explation for this difference and can it be prevented?
Why is picture different?
About squeezed letterbox
Were you referring to a free version of DVDFab? I could not find a screen with Video Effects Settings, like the one you displayed in your reply, on the free version of DVDFab I downloaded. Of course, I am not as familiar as you with the program, so I may have missed it.
Just a guess on my part since I don't have access to the free version but some DVD's have two versions of a movie on the same disc. (letterbox 16x9 and Full screen 4x3) but since the free version does a full disc rip to your hdd, and then you use a burner of your choice still the DVD player should allow you to select the version of your choice. Did you reauthor it with DVDshrink? Also some new widescreen TV's allow you to modify the picture, My Sony Bravia lets me select Full mode, Wide, Wide zoom and a few more choices. The problem may also be there.Last edited by W&B; 11-17-2009, 02:52 AM.
Originally posted by george3095 View PostI used DVDFab for the first time and was pleased with the results: the picture was in Letterbox format (bars across top and bottom - only. Then, flush with success, tried another DVD. This time, the picture was in Letterbox format BUT it had black bars on all sides. Since I could not have fifddled with settings, is there an explation for this difference and can it be prevented?Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
This is the DVD to Mobile function of DVD Fab. If you have only the free version of Fab, you don't have this option although it will function in the "30 Day Trial"
Download the latest version 6.2.0.5 from the links in this forum.
Originally posted by george3095 View PostWere you referring to a free version of DVDFab? I could not find a screen with Video Effects Settings, like the one you displayed in your reply, on the free version of DVDFab I downloaded. Of course, I am not as familiar as you with the program, so I may have missed it."Beer is living proof that God loves us and wants us to be happy."- Benjamin Franklin 1706-1790
I should have been more specific about my experience with DVDFab to help point to a solution. I used DVD to Mobile, Generic. After all was done, I viewed the movie, from a file, on my monitor, using VLC Media Player. The DVD I was working from had the widescreen VOBs on one side and the 3x4 version on the other. I picked the widescreen side and DVDFab, after analyzing the DVD, correctly showed the 9x16 format of the movie.
I have to say that DVDDecrypter had no success with the two DVDs on which I later used DVDFab. That was excellent, except for the "squeezed" widescreen result with one DVD. I probably should buy DVDFab.
Thanks to all who responded. I appreciate your help.
