Video/Audio problems w/ latest version - any advice?
    Been having some serious problems with the latest version. The resulting rips are about 5-10 seconds off w/ audio. The video picture has been horrible... showing horizontal lines across the hole picture, as though you are watching on a cheap 7 inch TV. Any thoughts? I have owned for about 6-8 months now... never had a problem with the tool in the past.
    Hi mjoyce
    Have no idea what the problem maybe without more information on what you are doing and also posting the logs the default location is:
    Please use attachment button and attach your most recent, Internal and Burn log(s) and post right here.
    CBR929
    Could a Mod please move this out of general chat and to the appropriate place once we figure it out where it needs to be...
    Thanks
      There are many post regarding the audio sync problems.
      Did you get your problems solved on your other thread?
        Threads are free, but one per problem is enough. Please continue to use the one you started earlier. This one is closed.
