DVDFab: pls help i'm an idiot
    pls help i'm an computer idiot, and need some help pls
    i have approx 200hrs of ufc windows media files that i what to burn onto disk,which program do i use? thanx
    DVDFab will not create a DVD from files (yet?). You might follow one of the guides here:
    How to author a basic DVD
      Unless you want to change the files to some other format, you can use any disc burning application to burn them. Several are listed in with download links if you don't already have something.
