Under Common Settings
    Under common settings; DVD Copy section what is " Create dvdid .xml which can be used by Windows Media Center "
    This creates a small file that WMC can use to get info on the DVD title from the internet.
      Thanks so much, will try "checking" on next dvd.
        signals, just wanted to say thank you again, after 3 to 4 hours, i've found all of the dvdid files for my movies, except for about 9. Now when i go to movies under WMC i have clip art and a synopsis of each movie which helps as i get older i tend to forget things, LOL. Have a great weekend, later.
