apacalypto
    apacalypto
    i am trying to convert apacalypto to avi, i cannot the get the subtitles at the beginnning of the movie to work. the 2 files seem to be there, (idx & another 1), but the subtitles do not display. any ideas?
    If you are working from the original Region 1 DVD, you need to put a checkmark in the top (I think it is the top one) english subpicture stream, then do not put a check in the "display only forced subpicture" box, and select direct render to video. This will provide the subpictures for the dialog of the movie, the subtitles begin when they kill the boar.
