i cannot get DVDfab to save the target drive. i have the target drive that i set in the settings. It will save it if I copy multiple discs one after another. But if I close the program and then reopen it fails to save the target drive. Any suggestions would be appreciated.
DVDfab will not save target drive
Guest
Note: For hard drive targets, this was a problem with the early Qt Beta versions, but is not a problem with v8.0.9.0, it works correctly (as did v8.0.8.9 Beta).Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Thanks. i do have one more question in regards to the default auto play in windows 7. DVDfab shows up as an option for DVD but not for Blu Ray. Is there a way to get it to show up under blu ray. Also even when i do select DVDfab to start up when a DVD is inserted it does not always work correctly meaning i have to manually start DVDfab instead of the auto play feature starting it. Maybe this is a windows thing but if not i would appreciate how to get it to work properly. Thanks again.
