True Grit
    True Grit
    I'm having problems watching the movie True Grit after burning it. I couldn't burn the whole disc because it was over 20GB of memory. I chose three different versions of the movie and none seem to play on my DVD. Help! Here is my log. Thanks
    2011-06-07 16:32:10 ---- ******************** Log session stop 07-Jun 16:32:10.976 PID 8068********************
    2011-06-07 16:29:33 Info WRITE SUCCESS: Disc written
    2011-06-07 16:29:33 Info Finalization Time 00:00:29 - Total completion time 00:07:37
    2011-06-07 16:29:04 Info Write finished in 00:07:08 - Finalization start here. Avg. burn rate 5.44
    2011-06-07 16:22:21 Info Lead-in burning time (mS) 24639
    2011-06-07 16:21:56 Info Write started 1434464 sectors to write
    2011-06-07 16:21:56 Info Init success: DVD+R
    2011-06-07 16:21:56 Info Writing speed requested x8.0, effective x8.0
    2011-06-07 16:21:56 Info Available write speed: 16x ,12x ,8x ,6x
    2011-06-07 16:21:56 Info Media ID: MCC-004-00
    2011-06-07 16:21:56 Info Media type: DVD+R
    2011-06-07 16:21:55 Info Scanned files #7, folder #2 - total size 2936662016 b. (2.73 Gb.)
    2011-06-07 16:21:55 Info Inserted media type : DVD+R
    2011-06-07 16:21:55 Info Write started
    2011-06-07 16:21:51 Info Writable disc DVD+R inserted. Ready to write
    2011-06-07 16:21:29 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
    2011-06-07 16:21:29 Info Drive has Serial ATA physical interface
    2011-06-07 16:21:29 Info New Drive selected : 0:0:0 - HP DVD Writer 1170r WH24 [F] (Usb)
    2011-06-07 16:21:21 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
    2011-06-07 16:21:21 Info Drive has Serial ATA physical interface
    2011-06-07 16:21:20 Info New Drive selected : 0:0:0 - HP DVD Writer 1170r WH24 [F] (Usb)
    2011-06-07 16:17:16 Info Disc (DVD-ROM) not empty.
    2011-06-07 16:17:14 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
    2011-06-07 16:17:14 Info Drive has Serial ATA physical interface
    2011-06-07 16:17:14 Info New Drive selected : 0:0:0 - HP DVD Writer 1170r WH24 [F] (Usb)
    2011-06-07 16:16:07 Info Current Drive selected : 0:0:0 - HP DVD Writer 1170r WH24 [F] (Usb)
    2011-06-07 16:16:07 Info Using Advanced SPTI interface
    2011-06-07 16:16:07 Info System default language : English (United States)
    2011-06-07 16:16:07 Info User default language : English (United States)
    2011-06-07 16:16:07 Info DLL Version : 4.0.19.487
    2011-06-07 16:16:07 Info DLL : C:\Program Files (x86)\DVDFab 8 Qt\vso_hwe.dll
    2011-06-07 16:16:07 Info Version : 8, 0, 9, 5
    2011-06-07 16:16:07 Info ExeName : C:\Program Files (x86)\DVDFab 8 Qt\DVDFab.exe
    2011-06-07 16:16:07 Info OS : Microsoft Windows Vista Home Premium (Build 6002: Service Pack 2)
    2011-06-07 16:16:07 ---- ******************** Log session start 07-Jun 16:16:07.495 PID 8068********************
    You are using the wrong version of DVDFab. Please update to v8.0.9.7, it has a fix for True Grit.
      Hi dragongirl2010, I haven't seen you for ages!!!
      How you've been?
      Your log surprised me... a lot!!
      First of all, why da heck you are still using VSO??? Switch it to ImgBurn immediately, you know how.
      Second of all, there's version 8.0.9.7 where True Grit problems were solved. Why da heck you still using 8.0.9.5 for this movie? Go and update your Fab immediately...
      And come back here with good result
      sigpic
        link to download V8097
          I know. Did u miss me? Thanks for the info about the new update. And I tried to change it to imgburn but for some reason my computer n burner advise me not to do it because is going to interfer with their performance. Well, I'll do it later. Thanks again!
