Useing bluray driver and bluray burner same time
    Put bluray movie in driver and blank in burner so it will download while i leave. But the movie always show cannot open not playable. I got geforce 210 video card and i watch bluray movies all the time.But dvdfab won't let it open for some reason. There a setting i can't find in dvdfab somewhere? Can anybody help!!!!
    THANKS DALE
    Thread is not a Feature Request so moved to General Questions.
      Thanks
      I didn't think of that i was in a hurry!!
        I would create an ISO first, mount it and make sure it plays okay before you burn it.
        At that point you'll know if DVDfab is messing up on the encode or the burner is making a bad burn.
          Here something too. I can put a regular dvd in and it works find. It go right to the source and start right up no problem. I also found out went i put the bluray in dvdfab won't open it and said it not playable but i click out of it go to the folder by the source and go to that drive click on that it start running find i don't get it. If you can there a setting some place? THANKS
            Your problem is not clearly described. Is it an original purchased Blu-ray disc that does not open or is it one that you burned? What version of DVDFab? Please post the DVDFab internal log. Are you using Blu-ray Copy mode, trying to copy a Blu-ray Disc?
              Hello
              It's the burn one that doesn't open it's said not playable.
                dvdfab won't open
                This is what it says went you try to open dvdfab. The application has failed to start because it's side by side configuration is incorrect. please see the application event log for more detail? What does that mean and that log at?
                thank DALE
                C/PROGRAM FILES/DVDFAB 8/REGOPERATOR EXE
                  Hi DALE
                  Please see this post
                  and post in this thread
                  CBR929
                    Two threads merged.
