Blu-ray to iso
    Blu-ray to iso
    Hi, does anyone know if transformer 2, monster inc., and star trek is supported by the last version 6.2.0.5?
    I've seen post where Transformers 2 and Star Trek XI has been ripped to hdd but not sure about Monsters Inc.
      Just used the search function, type the title name to find the threads, works great.
        If you are talking about Blu-ray, you may need to use v6.2.0.2 beta. The BD+ removal is not present in v6.2.0.5. If you are talking about standard DVDs, either of the latest versions should work for these discs for registered users (not HD Decrypter).
          Thanks to all
