Ha ha, you beat me to it
write speed problems
Originally posted by hellnbak View PostHuh, I've never heard that before. Why would burning at a slower speed be bad? I've always heard that a slower burn is a better burn
The old adage for burning "speed kills" is not always correct.
As you've seen, you can't even burn this media "badly" at 2.4X.
You have a great burner and decent to excellent quality media.
Do you happen to know if the manufacturer is TY, MMC, Sony or Ricoh?
I recommend burning this stuff at 8X, and you can probably burn it at 12X without issues, especially if it's not Ricoh.If it ain't broke, don't fix it!
@Wild & Blue ..Excellent job helping hellnbak .... two thumbs up ... great job !!!
@hellnbak ... dont forget to DONATE to LUK (Lightning UK) the developer of ImgBurn. ImgBurm is the BEST burning tool on the PLANET, no bloatware, been using since it's inception. Once you start using it you won't use anything else.Last edited by AlienX69; 11-21-2009, 02:46 PM.AX
The default Log File location: C:\Documents and Settings\"User Acct"\My Documents\DVDFab\Log
Originally posted by AlienX69 View Post@Wild & Blue ..Excellent job helping hellnbak). But this thread should be an example why to always post the needed info as was asked early on and never hesitate to ask how to do something.
