'Clean' Uninstall
    'Clean' Uninstall
    I've done a search but can't find anything regarding a 'Clean' uninstall of DVDFab - I Have 8085 (Works great) and 8106 installed but am not using 8106 due to it's many problems and unreliability - I'd like to do a clean uninstall of both and then start again - Does anyone have a procedure for this please?
    Win 7, professional, 64 bit version
    Thanks
    Use the uninstaller that comes with the product, it works well. You can run a registry cleaner afterwards, but if you do you will have to reset all Settings and re-register it.
      Clean Uninstall
      Thanks for the response - I have 'Registry Mechanic' -- Will this do the job of cleaning out the registry satisfactorily?
        Yes, it will
        sigpic
          Clean Uninstall
          Thanks all
