DVD "clone" option
    DVD "clone" option
    Hi
    please just reply if you know 100% the answer
    Is the option "DVDcopy">"clone" the same as i use passkey+alcohol?
    in other words:
    is the output iso an exact and "real" 1:1 clone copy/dvd as is using other mastering tools? (byte by byte/sector by sector)
    thank you for answer
    Clone reads bit-by-bit, but the copy is not exact since copy protection is removed. You have the option to use the original IFOs in Clone, but then UOPs etc. will remain. The file positions on the cloned disc should be the same as on the original. Don't know about the other product, inquire elsewhere.
      remove protection is Ok , its fab's job
      thank u for reply signals
        hi as far i can see with isobuster the fileposition is the same as the original
        last question what you mean with UOP?
          Hi moonie2001
          UOP= User Operation Prohibitions
          Like if watching a movie and you try to skip the FBI warning and are unable to do so, and you get a warning Operation Prohibited.
          CBR929
            Also known as PUOs, Prohibited User Operations, in some forums.
            You should find the disc layout to be identical.
