Is there a new Official Release 8.1.1.2QT, shows on home page, but not in the forum?
8.1.1.2qt
It is here now.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Not that I have seen. Save the installer to your HDD, don't click on the "Run" option in the download dialog box. Always select "Run as administrator" when installing.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Originally posted by adelphia View PostMine won't install. Just gets to the page with "Please wait while we install" and a cancel button and then just sits there. Windows 7 x64. Only way to stop it is Task Manager. Anyone else having issues?
Maybe silly to ask, but did you try to install it with administrator rights?----------------------------------------------------------------------------------------------------------
Searching for yourself is a lifetime journey.
Life is what happens in between.
Guest
I have seen a report [not on this forum] of the download from this forum link resulting in problems.
Deleting and then downloading from the main page solved the problem.
