Audio dropout?
    Audio dropout?
    Any idea why the audio would suddenly disappear? It's happened a couple of times on discs. I stop the movie, go back a chapter & no problems.
    Not a big concern, just wondering?
    Hi jrogers1965
    Please use attachment button and attach your most recent, Internal and Burn log(s) and post right here.
    CBR929
      0m 02.96s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 1
      0m 03.02s: Qt Translator file load success
      0m 14.13s: detected dvd
      0m 14.18s: drive E
      0m 14.19s: dvd type 1
      0m 14.19s: volume label VOYAGER_S5D1
      0m 16.52s: got copyright 1 fe
      0m 16.81s: got udf/iso
      0m 17.73s: got discinfo
      0m 17.75s: pathplayer enabled
      0m 41.09s: got dvdinfo
      0m 41.27s: opened dvd
      13m 49.33s: detected dvd
      13m 49.52s: drive E
      13m 49.55s: dvd type 0
      13m 49.56s: volume label
      I 14:03:51 ImgBurn Version 2.5.5.0 started!
      I 14:03:51 Microsoft Windows 7 Home Premium x64 Edition (6.1, Build 7601 : Service Pack 1)
      I 14:03:51 Total Physical Memory: 3,931,448 KB - Available: 2,441,508 KB
      I 14:03:51 Initialising SPTI...
      I 14:03:51 Searching for SCSI / ATAPI devices...
      I 14:03:51 -> Drive 1 - Info: hp DVD-RAM GH40L RB0E (E (ATA)
      I 14:03:51 Found 1 DVD±RW/RAM!
      I 14:03:52 Operation Started!
      I 14:03:52 Building Image Tree...
      I 14:03:52 Checking Directory Depth...
      I 14:03:52 Calculating Totals...
      I 14:03:52 Preparing Image...
      I 14:03:52 Checking Path Length...
      I 14:03:52 Contents: 17 Files, 2 Folders
      I 14:03:52 Content Type: DVD Video
      I 14:03:52 Data Type: MODE1/2048
      I 14:03:52 File System(s): ISO9660, UDF (1.02)
      I 14:03:52 Volume Label: VOYAGER_S5D1
      I 14:03:52 IFO/BUP 32K Padding: Enabled
      I 14:03:52 Region Code: 1, 2, 3, 4, 5, 6, 7, 8
      I 14:03:52 TV System: NTSC
      I 14:03:52 Size: 4,509,161,472 bytes
      I 14:03:52 Sectors: 2,201,739
      I 14:03:52 Image Size: 4,509,794,304 bytes
      I 14:03:52 Image Sectors: 2,202,048
      I 14:03:52 Operation Successfully Completed! - Duration: 00:00:00
      I 14:03:52 Source File: -==/\/[BUILD IMAGE]\/\==-
      I 14:03:52 Source File Sectors: 2,202,048 (MODE1/2048)
      I 14:03:52 Source File Size: 4,509,794,304 bytes
      I 14:03:52 Source File Volume Identifier: VOYAGER_S5D1
      I 14:03:52 Source File Volume Set Identifier: 3F0A707A002199B3
      I 14:03:52 Source File Application Identifier: IMGBURN V2.5.5.0 - THE ULTIMATE IMAGE BURNER!
      I 14:03:52 Source File Implementation Identifier: ImgBurn
      I 14:03:52 Source File File System(s): ISO9660, UDF (1.02)
      I 14:03:52 Destination Device: [0:1:0] hp DVD-RAM GH40L RB0E (E (ATA)
      I 14:03:52 Destination Media Type: DVD+R (Disc ID: CMC MAG-M01-00) (Speeds: 4x, 8x, 12x, 16x)
      I 14:03:52 Destination Media Sectors: 2,295,104
      I 14:03:52 Write Mode: DVD
      I 14:03:52 Write Type: DAO
      I 14:03:52 Write Speed: 8x
      I 14:03:52 DVD+R Reserve Track: No
      I 14:03:52 Link Size: Auto
      I 14:03:52 Lock Volume: Yes
      I 14:03:52 Test Mode: No
      I 14:03:52 OPC: No
      I 14:03:52 BURN-Proof: Enabled
      I 14:03:52 Write Speed Successfully Set! - Effective: 11,080 KB/s (8x)
      I 14:03:54 Filling Buffer... (40 MB)
      I 14:04:04 Writing LeadIn...
      I 14:04:29 Writing Session 1 of 1... (1 Track, LBA: 0 - 2202047)
      I 14:04:29 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 2202047)
      I 14:11:19 Synchronising Cache...
      I 14:11:20 Closing Track...
      I 14:11:23 Finalising Disc...
      I 14:12:00 Exporting Graph Data...
      I 14:12:00 Graph Data File: C:\Users\Jon\AppData\Roaming\ImgBurn\Graph Data Files\hp_DVD-RAM_GH40L_RB0E_WEDNESDAY-AUGUST-10-2011_2-03_PM_CMC_MAG-M01-00_8x.ibg
      I 14:12:00 Export Successfully Completed!
      I 14:12:00 Operation Successfully Completed! - Duration: 00:08:01
      I 14:12:00 Average Write Rate: 10,741 KB/s (7.8x) - Maximum Write Rate: 11,197 KB/s (8.1x)
      I 14:12:00 Close Request Acknowledged
      I 14:12:00 Closing Down...
      I 14:12:00 Shutting down SPTI...
      I 14:12:00 ImgBurn closed!
        What are you using to play the disc, PC or standalone DVD player? Try playing the intermediate or temp files from that disc if you still have them, see if the audio drops out when played from files on your hard drive. I would suspect your blank media is producing errors that your player has trouble decoding. If the audio dropouts occur during fast action scenes it would tend to substantiate this, especially if they happen near the end of the movie.
