Only select TV episodes to DVD
    Hello all...
    I have several season of TV episodes on DVD and what I want to do it to make my own "Best Of" DVDs...
    Take an episode from one disc... maybe 2 from the next... and put them all on the same DVD.
    Everything i have looked up only talks about ripping them to your computer... but I want them to go back onto a blank DVD.
    Thanks in advance...
    Originally posted by atari360 View Post
    Hello all...
    Rip the episodes to a hard drive first.
    Then merge them into one folder using the merge mode.
    Then burn the folder to a blank DVD.
    You can use Titlewrite to add a menu if you desire.
      Thanks much!
      Titlewrite?
        Thanks much!
        Titlewrite?
        Google
          I did that... I must be an idiot because I couldn't/can't find it =-(
          Is it TitlewriteR with an r?
            Yes, TitlewriteR.
              I guess it would help if I spelled it correctly.
              Titlewriter is a program to used to add DVD_TEXT, and (Re)Add Original or Generic Menus to Dvd Compiliations (Specifically designed for DVDShrink reauthored mode Compiliations).
