I have a license for DVDFab5 and had to rebuild my computer due to virus issues. Is there an archive of older versions that I can access?
Old Versions
Guest
Originally posted by cstimart View PostI have a license for DVDFab5 and had to rebuild my computer due to virus issues. Is there an archive of older versions that I can access?
Scroll down, the oldest version listed is 5250
You can download a new license key from the member area on the DVDFab website. If your license is not expired, you can get a key for the latest version. All you need is access to the email address you used for the purchase.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Originally posted by signals View PostYou can download a new license key from the member area on the DVDFab website. If your license is not expired, you can get a key for the latest version. All you need is access to the email address you used for the purchase.
Have you install and enter the key "as administrator"?sigpic
What is your OS?sigpic
Did you download the new key from the Member center on the DVDFab website? The download page will show you what licenses you have and when they expire, so that you will know if DVDFab is reading the key properly.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
If you had Platinum, you should get DVD Copy and DVD RIpper free. Platinum had a lifetime license.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
