Can not burn Blu-ray to DVD-9
    Blank Media Can not burn Blu-ray to DVD-9
    Iam trying to burn a blu-ray movie to a dvd-9 1080p. I am using dvd+r dl memorex and imation disc. Neither of them will complete the burn. I have made 22 coasters. What am I doing wrong?
    First and foremost is the media you're using.
    The only useable +R DL discs are the Verbatim with the AZO label on the package. Anything else will allow you to continue as a coaster factory.
    DC
      Blu-ray to DVD+R DL
      Thanks for the information.
        Please also post a burn log and internal log from one of these conversions. DC is right about the media, but it could be something else also.
          Blu-ray to DVD-9
          ******************** Log session stop 11-Sep 16:52:15.986 PID 6056********************
          2011-09-11 15:58:32 Error WRITE FAILED: write error occured at 28.1 percent of the write
          2011-09-11 15:58:27 Error Write error at 1162512 (16) - Code 05 21 02 [Illegal request, Invalid address for Write]
          2011-09-11 15:52:44 Info Lead-in burning time (mS) 1173
          2011-09-11 15:52:43 Info Write started 4140320 sectors to write
          2011-09-11 15:52:43 Info Init success: DVD+R Dual Layer
          2011-09-11 15:52:43 Info Init DVD+R Dual Layer: Layer change set to LBA 2070176 (3.95 Gb.)
          2011-09-11 15:52:25 Info Writing speed requested x6.0, effective x6.0
          2011-09-11 15:52:21 Info Available write speed: 6x ,4x
          2011-09-11 15:52:21 Info Media ID: RITEK-S04-42
          2011-09-11 15:52:21 Info Media type: Dual Layer DVD+R
          2011-09-11 15:52:21 Info Ultra DMA mode 5 (ATA100)
          2011-09-11 15:52:21 Info Scanned files #9, folder #7 - total size 8477899396 b. (7.90 Gb.)
          2011-09-11 15:52:21 Info Inserted media type : DL DVD+R
          2011-09-11 15:52:21 Info Write started
          2011-09-11 14:32:34 Info Writable disc DL DVD+R inserted. Ready to write
          2011-09-11 14:32:31 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
          2011-09-11 14:32:31 Info Drive has IDE-ATAPI physical interface
          2011-09-11 14:32:31 Info New Drive selected : 1:0:0 - ATAPI iHES208 2 8L05 [E] (Ide)
          2011-09-11 14:31:03 Info Current Drive selected : 3:0:0 - PIONEER BD-RW BDR-203 1.13 [D] (Ide)
          2011-09-11 14:31:03 Info Using Advanced SPTI interface
          2011-09-11 14:31:03 Info System default language : English (United States)
          2011-09-11 14:31:03 Info User default language : English (United States)
          2011-09-11 14:31:03 Info DLL Version : 4.0.19.487
          2011-09-11 14:31:03 Info DLL : C:\Program Files (x86)\DVDFab 8 Qt\vso_hwe.dll
          2011-09-11 14:31:03 Info Version : 8, 0, 9, 8
          2011-09-11 14:31:03 Info ExeName : C:\Program Files (x86)\DVDFab 8 Qt\DVDFab.exe
          2011-09-11 14:31:03 Info OS : Microsoft Windows 7 Home Premium (Build 7601: Service Pack 1)
          2011-09-11 14:31:03 ---- ******************** Log session start 11-Sep 14:31:03.032 PID 6056********************
            Hi djspinnnn
            If you would like to try and salvage these disc's I suggest installing ImgBurn in the link in my signature and remember to set up the AWS in ImgBurn and your burn speed to 1/2 the rated speed of your disc's, which in this case with the disc your using 4X.
            Consider what DarthCopier suggested buy using quality media, yours are considered garbage.
            Hope this helped
            CBR929
              Thank you!
