Removing trailers
    Removing trailers
    Is it not possible to remove forced trailers? I don't see it in the options so figured I should make sure
    The sole purpose of this program is to remove protection and annoying content!
    What exactly are you trying to do and what actions you take?
    sigpic
      Well, it could be that I'm missing some options because I'm just using the free decryptor but what I was hoping was to see some options like xxxxxx has. All I'm looking to do is rip discs to folder structure without any of the forced content at the beginning. In xxxxxx there options explicitly labeled for it. I'm not seeing it in DVDFab
      I still want the menus, extras etc. I just don't want to have to sit through ads till I get to the option to play the movie
      Last edited by Guest; 09-21-2011, 10:36 PM. Reason: I removed mention of other software from you first post for a reason. Do not mention it again
        Are you doing it under "Full Disc" or "Main Movie?" That could be the problem
          @jrogers1965
          and obviously "full disc". However, free and short version of DVDFab HD Decrypter would not support customization (is this a word?).
          sigpic
            Ok that's fine. I am considering paying for the product but it's still unclear to me of what I can do with the full...
            There may be unskippable screens / trailers at the beginning of some discs. Is it possible to remove this using the app? Whether it's the paid or free app. I read in another forum that it won't remove but will allow you to at least skip. I'm ok with this too if that's possible
            I still want working menus etc while being ripped to a folder structure. Isn't the main movie just ripping out the m2ts file?
              Yes, it is possible in some cases depending on the copy mode and the way the original disc is authored. The most flexible is Customize, which is not available in the free version. If you haven't already used it up, DVDFab comes with a 30-day free trial that will let you see how it works. Main Movie mode also skips all the junk and is (I think) still available in the free version.
