coreAVC
    coreAVC
    Was just checking back, no hurry! I wanted to know if coreAVC 3.0 was still in the future to be supported?
    Is coreAVC really that inportant with Blu-ray? When I had my old rig and only doing DVDCOPY it would really spead up my process time.
    We have support CoreAVC 3.0 decoder now.
    But some issue in it. Please wait patient.
      CoreAVC
      OK, thank you very much!
        I don't think CoreAVC is even active for any DVD Copy functions.
          AVC 3.0.1 is now out.
          When decoding use the DXVA setting in CoreAVC it activates both Cuda and and other functions using DirectX. Also check Trace Icon in the settings panel. You can also download DXVA Checker to see if it's actually working.
          Now for my question:
          When using CoreAVC, no matter if it's CUDA or DXVA i get a sound sync problem in the DVDFab output. I think I saw something regarding this in another post. Is this something that will be looked at and mayby fixed?
          DVDFab 8.1.3.2 (2011/11/24 07:53:01)
          0m 01.77s: Qt Translator file load success
          0m 01.77s: import key file J:\ 1
          0m 01.98s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 1
          740m 14.73s: D 986C54ED
          740m 14.74s: got vuk
          740m 14.74s: got unit key 1
          740m 26.82s: got extended bdinfo
          740m 26.82s: opened blu-ray
          0m 20.90s: detected blu-ray
          0m 20.90s: drive J
          0m 20.90s: blu-ray type 1
          0m 20.90s: volume label Salvation Boulevard NO_SW_FI
          0m 34.33s: detected blu-ray
          0m 34.33s: drive J
          0m 34.33s: blu-ray type 1
          0m 34.33s: volume label Salvation Boulevard NO_SW_FI
          0m 50.54s: aacs 1 bd+ 0
          1m 09.78s: got discinfo
          1m 28.29s: got bdmv
          1m 28.60s: Vendor: PLEXTOR
          1m 28.60s: Product: BD-R PX-B900A
          1m 28.60s: Revision: 1.01
          1m 28.60s: Vendor specific: 12/07/06BLE8
          1m 28.60s: AACS version: 1
          1m 28.60s: Number of concurrent AGIDs: 1
          1m 28.60s: Supports bus encryption: NO
          1m 28.60s: Supports binding nonce generation: YES
          1m 28.62s: Supports Hybrid discs: NO
          1m 28.62s: got agid 3
          1m 28.68s: sent host cert chal
          1m 28.87s: got drive cert chal
          1m 28.87s: BEC 0
          1m 28.87s: DRIVE_VENDOR 0x0001
          1m 28.95s: got drive key
          1m 29.71s: got host key signature
          1m 29.71s: verified drive signature
          1m 29.71s: verified host signature
          1m 29.84s: sent host signature and key point
          1m 29.84s: got bus key
          1m 29.85s: got agid 3
          1m 29.93s: sent host cert chal
          1m 29.93s: got drive cert chal
          1m 29.93s: BEC 0
          1m 29.93s: DRIVE_VENDOR 0x0001
          1m 30.01s: got drive key
          1m 30.01s: got host key signature
          1m 30.02s: verified drive signature
          1m 30.02s: verified host signature
          1m 30.13s: sent host signature and key point
          1m 30.13s: got bus key
          1m 30.13s: got volume id
          1m 30.13s: got volume id mac
          1m 30.13s: volume id is correct
          1m 30.13s: got vid
          1m 31.18s: blu-ray 452ED568922492A87C55DD6D4AF51C43382EFE6F
          1m 40.02s: cert BEE=0x00
          1m 40.43s: D 986C54ED
          1m 40.44s: got vuk
          1m 40.60s: got unit key 1
          1m 47.31s: got extended bdinfo
          1m 47.31s: opened blu-ray
          8m 02.66s:
          8m 02.66s: info: create config(5)
          8m 02.66s: info: convert profile(m2ts.default)
          8m 02.68s: info: bluray playlist(1007),angle(0),chapter(1->16),3D(0)
          8m 02.68s: info: streams((4113.2)(4352.2)(4609.8))
          8m 02.68s: info: set output video frame_rate(24/1)
          8m 02.68s: info: subpicture preset(1), mode(0)
          8m 02.69s: CoreAVC for video decoding enabled
          8m 02.82s: CUDA GPU acceleration for video encoding enabled
          8m 02.82s: info: h264_encode: encode param profile(2) level(41) bitrate(7161)
          8m 02.96s: info: subpicture(4609) mode(0)
          8m 02.96s: info: connect to sub render filter
          8m 02.97s: info: processing source(00012.m2ts)
          84m 05.68s:
          ------ finish mobile work ------
            I just noticed I got a sound sync problem of 21 ms ahead even if i'm not using CoreAVC???
            DVDFab 8.1.3.2 (2011/11/24 15:57:22)
            0m 01.57s: Qt Translator file load success
            0m 01.59s: import key file J:\ 1
            0m 01.77s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 1
            0m 07.26s: detected blu-ray
            0m 07.26s: drive J
            0m 07.26s: blu-ray type 1
            0m 07.26s: volume label CARS2_D1
            0m 08.92s: aacs 1 bd+ 0
            0m 10.32s: got discinfo
            0m 10.71s: got bdmv
            0m 10.73s: Vendor: PLEXTOR
            0m 10.73s: Product: BD-R PX-B900A
            0m 10.73s: Revision: 1.01
            0m 10.73s: Vendor specific: 12/07/06BLE8
            0m 10.73s: AACS version: 1
            0m 10.73s: Number of concurrent AGIDs: 1
            0m 10.73s: Supports bus encryption: NO
            0m 10.73s: Supports binding nonce generation: YES
            0m 10.73s: Supports Hybrid discs: NO
            0m 10.73s: got agid 3
            0m 10.81s: sent host cert chal
            0m 10.81s: got drive cert chal
            0m 10.81s: BEC 0
            0m 10.81s: DRIVE_VENDOR 0x0001
            0m 10.88s: got drive key
            0m 11.65s: got host key signature
            0m 11.65s: verified drive signature
            0m 11.65s: verified host signature
            0m 11.76s: sent host signature and key point
            0m 11.76s: got bus key
            0m 11.77s: got agid 3
            0m 11.85s: sent host cert chal
            0m 11.85s: got drive cert chal
            0m 11.85s: BEC 0
            0m 11.85s: DRIVE_VENDOR 0x0001
            0m 11.93s: got drive key
            0m 11.93s: got host key signature
            0m 11.94s: verified drive signature
            0m 11.94s: verified host signature
            0m 12.05s: sent host signature and key point
            0m 12.05s: got bus key
            0m 12.05s: got volume id
            0m 12.05s: got volume id mac
            0m 12.05s: volume id is correct
            0m 12.05s: got vid
            0m 12.16s: blu-ray BDDB254B603E3BFD1F18B4278FB7D66D479229B1
            0m 12.83s: cert BEE=0x00 same
            0m 13.26s: D 3B3B0C8F
            0m 13.26s: got vuk
            0m 13.66s: got unit key 1
            1m 39.51s: got extended bdinfo
            1m 39.51s: opened blu-ray
            5m 55.37s:
            5m 55.37s: info: create config(5)
            5m 55.37s: info: convert profile(m2ts.default)
            5m 55.37s: info: bluray playlist(956),angle(0),chapter(1->34),3D(0)
            5m 55.37s: info: streams((4113.2)(4352.2)(4610.8))
            5m 55.38s: info: set output video frame_rate(24000/1001)
            5m 55.38s: info: subpicture preset(1), mode(0)
            5m 55.38s: try to use gpu acceleration(1) for video decoding
            5m 55.38s: CUDA GPU acceleration for video decoding enabled
            5m 55.38s: CUDA GPU acceleration for video encoding enabled
            5m 55.40s: info: h264_encode: encode param profile(2) level(41) bitrate(5538)
            5m 55.52s: info: subpicture(4610) mode(0)
            5m 55.52s: info: connect to sub render filter
            5m 55.52s: info: processing source(00800.m2ts)
            6m 19.86s: info: processing source(00920.m2ts)
            6m 51.53s: info: processing source(00870.m2ts)
            8m 10.60s: info: processing source(00921.m2ts)
            8m 21.66s: info: processing source(00871.m2ts)
            10m 35.08s: info: processing source(00922.m2ts)
            10m 56.74s: info: processing source(00872.m2ts)
            11m 21.70s: info: processing source(00903.m2ts)
            11m 41.66s: info: processing source(00923.m2ts)
            11m 54.90s: info: processing source(00873.m2ts)
            13m 22.04s: info: processing source(00925.m2ts)
            13m 36.05s: info: processing source(00904.m2ts)
            13m 47.71s: info: processing source(00927.m2ts)
            14m 00.62s: info: processing source(00905.m2ts)
            14m 23.13s: info: processing source(00874.m2ts)
            14m 51.98s: info: processing source(00906.m2ts)
            15m 28.58s: info: processing source(00930.m2ts)
            16m 01.27s: info: processing source(00875.m2ts)
            16m 27.09s: info: processing source(00907.m2ts)
            16m 44.22s: info: processing source(00876.m2ts)
            17m 19.55s: info: processing source(00932.m2ts)
            17m 32.64s: info: processing source(00877.m2ts)
            18m 43.55s: info: processing source(00908.m2ts)
            18m 55.26s: info: processing source(00878.m2ts)
            19m 57.33s: info: processing source(00934.m2ts)
            20m 11.44s: info: processing source(00902.m2ts)
            23m 50.93s: info: processing source(00935.m2ts)
            24m 44.27s: info: processing source(00909.m2ts)
            25m 21.33s: info: processing source(00879.m2ts)
            25m 42.81s: info: processing source(00910.m2ts)
            25m 56.81s: info: processing source(00880.m2ts)
            26m 37.29s: info: processing source(00938.m2ts)
            26m 48.04s: info: processing source(00911.m2ts)
            27m 17.51s: info: processing source(00881.m2ts)
            28m 42.87s: info: processing source(00912.m2ts)
            29m 28.03s: info: processing source(00941.m2ts)
            29m 40.40s: info: processing source(00882.m2ts)
            31m 19.45s: info: processing source(00942.m2ts)
            32m 54.75s: info: processing source(00883.m2ts)
            34m 58.36s: info: processing source(00943.m2ts)
            35m 09.38s: info: processing source(00884.m2ts)
            38m 05.88s: info: processing source(00944.m2ts)
            38m 18.83s: info: processing source(00885.m2ts)
            39m 03.85s: info: processing source(00945.m2ts)
            39m 14.00s: info: processing source(00913.m2ts)
            40m 02.52s: info: processing source(00886.m2ts)
            41m 39.66s: info: processing source(00947.m2ts)
            41m 54.36s: info: processing source(00887.m2ts)
            42m 12.25s: info: processing source(00948.m2ts)
            43m 08.54s: info: processing source(00888.m2ts)
            43m 32.15s: info: processing source(00949.m2ts)
            43m 49.36s: info: processing source(00889.m2ts)
            44m 10.98s: info: processing source(00914.m2ts)
            44m 33.13s: info: processing source(00890.m2ts)
            44m 51.39s: info: processing source(00915.m2ts)
            45m 02.06s: info: processing source(00891.m2ts)
            45m 49.48s: info: processing source(00916.m2ts)
            46m 05.64s: info: processing source(00892.m2ts)
            46m 56.81s: info: processing source(00953.m2ts)
            47m 14.38s: info: processing source(00917.m2ts)
            47m 29.14s: info: processing source(00893.m2ts)
            48m 15.03s: info: processing source(00918.m2ts)
            48m 34.62s: info: processing source(00894.m2ts)
            50m 21.44s: info: processing source(00956.m2ts)
            50m 32.30s: info: processing source(00919.m2ts)
            50m 43.25s: info: processing source(00958.m2ts)
            51m 06.73s: info: processing source(00895.m2ts)
            51m 39.31s: info: processing source(00959.m2ts)
            51m 53.96s: info: processing source(00896.m2ts)
            53m 17.75s: info: processing source(00960.m2ts)
            53m 36.52s: info: processing source(00897.m2ts)
            55m 34.63s: info: processing source(00961.m2ts)
            55m 47.07s: info: processing source(00898.m2ts)
            56m 16.81s: info: processing source(00962.m2ts)
            56m 26.75s: info: processing source(00900.m2ts)
            56m 58.54s: info: processing source(00963.m2ts)
            57m 09.76s: info: processing source(00901.m2ts)
            60m 01.87s: info: processing source(01000.m2ts)
            62m 45.09s: info: processing source(01002.m2ts)
            64m 05.73s: info: processing source(01004.m2ts)
            64m 25.84s:
