Hi, I am new to this forum. I have tried to find the solution to this problem with no prevail, so I apologize if this has been addressed and answered before. I buy all BR/DVD combos, and many come with the digital copy (which in my opinion is completely useless) Anyway, more often than not, the digital copy is on the same disc as the DVD. I want to copy the DVD so I can have a backup, which I always do, but because of the digital copy, the program thinks there are like 85 of the same movies, and it will not work because it is far too large of a file. Is there a way to fix this so I can just copy the DVD part, not the DC?
DVD Copy w/ Digital Copy issue
This is most likely a problem with the copy protection on the DVD content itself and probably has nothing to do with the digital copy, which is normally not inside the VIDEO_TS folder (which is all that DVDFab reads).
Let DVDFab analyze the disc, then post the internal log file of what it finds.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
I am not sure what you mean by the internal log file, but i got this:
nfo for drive [E:\] (DVDFab 8.0.0.5)
Drive region: 1
Disc type: Video DVD
Disc region: 1
Volume name: IRON_MAN_2_D3
Video standard: NTSC
Layer 0 size: 2060096 sectors (4023 MBytes)
Layer 1 size: 2060096 sectors (4023 MBytes)
CSS (Content Scramble System) protection is removed!
RC (Region Code) protection is removed!
RCE (Region Code Enhancement) protection is removed!
APS (Analog Protection System) protection is removed!
UOPs (User Operation Prohibitions) protection is removed!
Invalid PTTs protection is not found.
Invalid PGCIs protection is not found.
Invalid PGCs protection is not found.
Invalid TMAPs protection is not found.
Invalid CELLs protection is removed!
Invalid VOBUs protection is removed!
Fake vts 3 is removed!
1 fake vts protections are removed!
Potential bad sector (vts:2 title begin:0 end:195) is removed!
Potential bad sector (vts:4 title begin:0 end:4111) is removed!
Potential bad sector (vts:5 title begin:0 end:4111) is removed!
Potential bad sector (vts:5 title begin:990552 end:2010091) is removed!
Potential bad sector (vts:6 title begin:0 end:4111) is removed!
Potential bad sector (vts:7 title begin:0 end:4111) is removed!
Potential bad sector (vts:7 title begin:990552 end:2010091) is removed!
Potential bad sector (vts:8 title begin:0 end:4111) is removed!
Potential bad sector (vts:9 title begin:0 end:4111) is removed!
Potential bad sector (vts:10 title begin:0 end:4111) is removed!
Potential bad sector (vts:10 title begin:990552 end:2010091) is removed!
Potential bad sector (vts:11 title begin:0 end:4111) is removed!
Potential bad sector (vts:12 title begin:0 end:4111) is removed!
Potential bad sector (vts:12 title begin:990552 end:2010091) is removed!
Potential bad sector (vts:13 title begin:0 end:4111) is removed!
Potential bad sector (vts:14 title begin:0 end:195) is removed!
16 potential bad sector protections are removed!
Structure protection (ARccOS, RipGuard, etc.) is removed!
PathPlayer is disabled.
Hi phoenix316bub
Please try the latest version found here http://forum.dvdfab.com/showthread.php?t=15064
Also
Open Fab Click the Green √ top right > Protection > Path Player click Always Enabledclick OK restart Fab and try again.
CBR929Even if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
Your welcome.
