backup bluray and iso
    hello, I need your help
    happens to me when I backup a bluray if I transform the film into iso
    before burning, once recorded the record, when I look at my blue ray player from the living room to digest easily, whereas if I register after the backup operation directly without passing through the film when I watch the movie iso playback it works really bad. 'cause you think this happens?
    I have version 8.1.2.6 of the program properly registered and have a blue ray player from Samsung
    thanks for the help!
    Hi filmmaniacs
    I am sorry that I can't clearly understand the steps in your procedure. Please list the steps like this:
    1. decrypt and copy to hard drive BDMV folder, using DVDFab
    2. test playback on TV, all OK
    3. generate ISO using (???)
    4. test playback on TV, bad (drops frames, jerky playback etc. ???)
    My TV is connected to HDD via (wifi network, ethernet, ???)
      hi signals
      I run the main movie copy on hdd with dvdfab 8.1.2.6. registered version
      create iso image with imgburn 2560
      burn image with Nero Multimedia 10
      I play movies on player sitting SAMSUMG
      with this procedure, the backup discs work well!
      if instead
      Copy main movie run on hdd with dvdfab 8.1.2.6 registered version
      burn movie created with normal folders with dvdfab vso form
      I play movies on samsung player living
      the film works jerky lag image with sound
      I do not understand what difference do run a process rather than the other
      my pc have amd phenom 9500 quad core,4gb ram,2 hdd,2 bd writer sony optiarc bd-5300 sata,clock 1.80 ghz
      thanks for help
        Please post your log file!
          I tried replacing both the bd player is empty living room, and nothing 'changed
          this is the log file:
          VDFab 8.1.2.6 (2011/10/23 12:57:58)
          0m 00.96s: Qt Translator file load success
          0m 01.48s: option dvd2dvd 0 dvd2mobile 1 bluray2bluray 1 bd2mobile 0 bd23d 0 bd2dvd 0 file2mobile 1 filemover 0
          0m 47.78s: detected blu-ray
          0m 47.78s: drive F
          0m 47.78s: blu-ray type 1
          0m 47.78s: volume label TOY_STORY_3_D1
          0m 50.01s: aacs 1 bd+ 0
          0m 51.12s: got discinfo
          0m 51.35s: got bdmv
          0m 51.37s: Vendor: Optiarc
          0m 51.37s: Product: BD RW BD-5300S
          0m 51.37s: Revision: 1.04
          0m 51.37s: Vendor specific: 2011/02/17 13:59
          0m 51.37s: AACS version: 1
          0m 51.37s: Number of concurrent AGIDs: 2
          0m 51.38s: Supports bus encryption: NO
          0m 51.38s: Supports binding nonce generation: YES
          0m 51.38s: Supports Hybrid discs: NO
          0m 51.38s: got agid 0
          0m 51.44s: sent host cert chal
          0m 51.44s: got drive cert chal
          0m 51.46s: BEC 0
          0m 51.46s: DRIVE_VENDOR 0x0128
          0m 51.54s: got drive key
          0m 52.16s: got host key signature
          0m 52.18s: verified drive signature
          0m 52.18s: verified host signature
          0m 52.26s: sent host signature and key point
          0m 52.26s: got bus key
          0m 52.27s: got agid 0
          0m 52.33s: sent host cert chal
          0m 52.33s: got drive cert chal
          0m 52.33s: BEC 0
          0m 52.33s: DRIVE_VENDOR 0x0128
          0m 52.41s: got drive key
          0m 52.43s: got host key signature
          0m 52.43s: verified drive signature
          0m 52.43s: verified host signature
          0m 52.51s: sent host signature and key point
          0m 52.51s: got bus key
          0m 54.78s: got volume id
          0m 54.78s: got volume id mac
          0m 54.78s: volume id is correct
          0m 54.80s: got vid
          0m 55.77s: blu-ray F000EF75FD8A8387E24A7F589BEAB0584206B103
          0m 56.34s: cert BEE=0x00 same
          1m 02.44s: D 8F12BCE9
          1m 02.46s: got vuk
          1m 02.83s: got unit key 7
          1m 46.12s: got extended bdinfo
          1m 46.14s: opened blu-ray
          10m 50.05s: Blu-ray Copy: Main Movie
          10m 50.05s: Source: F:\BDMV\
          10m 50.05s: Playlist: 800
          10m 50.07s: Chapters: 1 -> 35
          10m 50.07s: TotalSize: 28975 MB
          10m 50.07s: SourceSize: 28975 MB
          10m 50.07s: RemoveHDAudio: 0
          10m 50.07s: CompressToAC3: 0
          10m 50.07s: OutputDisc: BDMV
          10m 50.08s: OutputTarget: BD50
          10m 50.08s: OutputVideo: 1080p/i
          10m 50.08s: info: enable bd copy(mode=0)
          10m 50.08s: info: streams()
          10m 50.08s: info: blu-ray copy begin (unit[elem[atomic[00296.m2ts],atomic[00515.m2ts],atomic[00514.m2ts],atomic[00516.m2ts],atomic[00298.m2ts],atomic[00322.m2ts],atomic[00507.m2ts],atomic[00323.m2ts],atomic[00301.m2ts],atomic[00324.m2ts],atomic[00302.m2ts],atomic[00325.m2ts],atomic[00303.m2ts],atomic[00326.m2ts],atomic[00304.m2ts],atomic[00327.m2ts],atomic[00305.m2ts],atomic[00328.m2ts],atomic[00509.m2ts],atomic[00329.m2ts],atomic[00307.m2ts],atomic[00330.m2ts],atomic[00308.m2ts],atomic[00331.m2ts],atomic[00309.m2ts],atomic[00341.m2ts],atomic[00310.m2ts],atomic[00332.m2ts],atomic[00311.m2ts],atomic[00333.m2ts],atomic[00312.m2ts],atomic[00334.m2ts],atomic[00313.m2ts],atomic[00335.m2ts],atomic[00513.m2ts],atomic[00336.m2ts],atomic[00315.m2ts],atomic[00337.m2ts],atomic[00316.m2ts],atomic[00338.m2ts],atomic[00317.m2ts],atomic[00339.m2ts],atomic[00318.m2ts],atomic[00340.m2ts],atomic[00319.m2ts],atomic[00521.m2ts],atomic[00342.m2ts]]])
          10m 50.10s: info: processing source(00296.m2ts)
          11m 04.76s: info: processing source(00515.m2ts)
          11m 10.71s: info: processing source(00514.m2ts)
          11m 37.55s: info: processing source(00516.m2ts)
          11m 43.65s: info: processing source(00298.m2ts)
          11m 53.68s: info: processing source(00322.m2ts)
          11m 56.95s: info: processing source(00507.m2ts)
          13m 28.27s: info: processing source(00323.m2ts)
          13m 48.19s: info: processing source(00301.m2ts)
          13m 53.51s: info: processing source(00324.m2ts)
          14m 02.87s: info: processing source(00302.m2ts)
          14m 16.64s: info: processing source(00325.m2ts)
          14m 21.29s: info: processing source(00303.m2ts)
          14m 30.26s: info: processing source(00326.m2ts)
          14m 46.14s: info: processing source(00304.m2ts)
          15m 00.46s: info: processing source(00327.m2ts)
          15m 06.41s: info: processing source(00305.m2ts)
          15m 11.18s: info: processing source(00328.m2ts)
          15m 18.98s: info: processing source(00509.m2ts)
          18m 55.64s: info: processing source(00329.m2ts)
          19m 13.95s: info: processing source(00307.m2ts)
          19m 46.70s: info: processing source(00330.m2ts)
          19m 51.34s: info: processing source(00308.m2ts)
          20m 02.78s: info: processing source(00331.m2ts)
          20m 20.55s: info: processing source(00309.m2ts)
          22m 14.18s: info: processing source(00341.m2ts)
          22m 18.27s: info: processing source(00310.m2ts)
          22m 27.69s: info: processing source(00332.m2ts)
          22m 41.26s: info: processing source(00311.m2ts)
          22m 59.25s: info: processing source(00333.m2ts)
          23m 12.26s: info: processing source(00312.m2ts)
          23m 32.66s: info: processing source(00334.m2ts)
          23m 36.36s: info: processing source(00313.m2ts)
          23m 42.79s: info: processing source(00335.m2ts)
          23m 52.23s: info: processing source(00513.m2ts)
          24m 05.38s: info: processing source(00336.m2ts)
          24m 16.11s: info: processing source(00315.m2ts)
          24m 35.66s: info: processing source(00337.m2ts)
          24m 39.82s: info: processing source(00316.m2ts)
          25m 24.81s: info: processing source(00338.m2ts)
          26m 10.15s: info: processing source(00317.m2ts)
          27m 01.80s: info: processing source(00339.m2ts)
          27m 19.78s: info: processing source(00318.m2ts)
          27m 24.70s: info: processing source(00340.m2ts)
          27m 29.14s: info: processing source(00319.m2ts)
          27m 51.92s: info: processing source(00521.m2ts)
          28m 23.71s: info: processing source(00342.m2ts)
          this is the ultimate bd backup work wrong without the iso process
            Does the iso file could play well on PC?
              hi wilson
              after you burn the iso file on blue ray blank disc works well on PC than on a living room player, but without the detour to iso discs work poorly even on PC
              I want to point out that not all burned discs without the detour to iso problems
              but sometimes one and sometimes not. I made up 3 transformers without passing the disc to iso and it works well anyway. and 'a mystery
              sorry for my english,i don't speak
                hello wilson
                you have some ideas on my problem? you can let me know?
                thanks
                  Originally posted by filmmaniacs View Post
                  hello wilson
                  thanks
                  It is so hard to imagine that the video quality is bad when copy movie to bd50.
                  Please also post your burn log.
                  Could you please give us some video screenshot?
                    hi wilson
                    this is the burn log file :
                    2011-10-23 16:17:39 ---- ******************** Log session stop 23-ott 16:17:39.741 PID 3824********************
                    2011-10-23 16:17:33 Info Disc ejected by user while parsing.
                    2011-10-23 16:17:31 Info Parsing disc ...
                    2011-10-23 16:17:05 Info WRITE SUCCESS: Disc written
                    2011-10-23 16:17:05 Info Finalization Time 00:00:19 - Total completion time 00:22:17
                    2011-10-23 16:16:45 Info Write finished in 00:21:58 - Finalization start here. Avg. burn rate 14,03
                    2011-10-23 15:54:47 Info Lead-in burning time (mS) 103
                    2011-10-23 15:54:47 Info Write started 11382112 sectors to write
                    2011-10-23 15:54:47 Info Writing speed requested x4.0, effective x4.0
                    2011-10-23 15:54:45 Info Available write speed: 4x
                    2011-10-23 15:54:45 Info Media ID: RITEK-BR2-00
                    2011-10-23 15:54:45 Info Media type: BD-R Sequential
                    2011-10-23 15:54:45 Info DMA is not available on this bus type
                    2011-10-23 15:54:45 Info Scanned files #9, folder #15 - total size 23308939800 b. (21,71 Gb.)
                    2011-10-23 15:54:45 Info Inserted media type : BD-R Sequential
                    2011-10-23 15:54:45 Info Write started
                    2011-10-23 15:54:41 Info Writable disc BD-R Sequential inserted. Ready to write
                    2011-10-23 15:54:40 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
                    2011-10-23 15:54:40 Info Drive has Serial ATA physical interface
                    2011-10-23 15:54:40 Info New Drive selected : 1:1:0 - Optiarc BD RW BD-5300S 1.04 [F] (Ide)
                    2011-10-23 13:51:27 Info Disc ejected by user while parsing.
                    2011-10-23 13:51:23 Info Parsing disc ...
                    2011-10-23 13:50:53 Info WRITE SUCCESS: Disc written
                    2011-10-23 13:50:53 Info Finalization Time 00:00:19 - Total completion time 00:22:28
                    2011-10-23 13:50:33 Info Write finished in 00:22:08 - Finalization start here. Avg. burn rate 13,72
                    2011-10-23 13:28:24 Info Lead-in burning time (mS) 100
                    2011-10-23 13:28:24 Info Write started 11214272 sectors to write
                    2011-10-23 13:28:24 Info Writing speed requested x4.0, effective x4.0
                    2011-10-23 13:28:22 Info Available write speed: 4x
                    2011-10-23 13:28:22 Info Media ID: RITEK-BR2-00
                    2011-10-23 13:28:22 Info Media type: BD-R Sequential
                    2011-10-23 13:28:22 Info DMA is not available on this bus type
                    2011-10-23 13:28:21 Info Scanned files #147, folder #15 - total size 22964550532 b. (21,39 Gb.)
                    2011-10-23 13:28:21 Info Inserted media type : BD-R Sequential
                    2011-10-23 13:28:21 Info Write started
                    2011-10-23 13:28:18 Info Writable disc BD-R Sequential inserted. Ready to write
                    2011-10-23 13:28:15 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
                    2011-10-23 13:28:15 Info Drive has Serial ATA physical interface
                    2011-10-23 13:28:15 Info New Drive selected : 0:1:0 - Optiarc BD RW BD-5300S 1.04 [E] (Ide)
                    2011-10-23 13:27:16 Info Current Drive selected : 0:1:0 - Optiarc BD RW BD-5300S 1.04 [E] (Ide)
                    2011-10-23 13:27:16 Info Using Advanced SPTI interface
                    2011-10-23 13:27:16 Info System default language : Italiano (Italia)
                    2011-10-23 13:27:16 Info User default language : Italiano (Italia)
                    2011-10-23 13:27:16 Info DLL Version : 4.0.20.488
                    2011-10-23 13:27:16 Info DLL : D:\program files\DVDFab 8 Qt\vso_hwe.dll
                    2011-10-23 13:27:16 Info Version : 8, 1, 2, 6
                    2011-10-23 13:27:16 Info ExeName : D:\program files\DVDFab 8 Qt\DVDFab.exe
                    2011-10-23 13:27:16 Info OS : Microsoft Windows 7 Ultimate (Build 7601: Service Pack 1)
                    2011-10-23 13:27:16 ---- ******************** Log session start 23-ott 13:27:16.430 PID 3824********************
                    I can not identify which one corresponds to the disk toy story 3, I hope you manage to find it!
                    thank you very much
                    p.s. i backing up to 25gb blank bluray, not 50 gb disc
                    I do not know how I can get you pictures of finding the defect that gives me problems, sorry!!
