Help with Frame Resolution
    Hi
    Please can someone help clarify the way frame resolution works.
    I cannot seem to find much info in the manual.
    For example this PAL DVD.
    VG_VS_FG: Title(20), Play Time(01:24:28)
    Original Frame Resolution (1024 x 576)
    Original Aspect Ratio (1.78:1)
    Cropped Aspect Ratio (1.78:1)
    Source Zoom: 51%
    Output Zoom: 80%
    Output Size: 690 x 388
    As you can see the original frame resolution shows as 1024 x 576 BUT DVDFAB automatically sets the output to 690 x 388
    So my question is, do I accept the default 690 x 388 or should I be changing the output size to match the 1024 x 576 of the original frame resolution.
    Thanks
    tokyojay
    You should select 690x388, it's cropped and keep the video Aspect Ratio.
      It depends on your playback device. For viewing on a cellphone/tablet or similar small screen device, 690x388 is probably more than adequate.
      Originally posted by tokyojay View Post
      Hi
      .............edited................
      Thanks
      tokyojay
        Hi
        Thanks for the replies..
        The resolution is for a DVD rip to MP4 but I was trying to understand why the output size was different from the original frame resolution so I was not sure if I was to set the output to 1024 x 576 to match the original or as you have stated, to leave it set to 690x388
        Thanks for your help
        Tokyojay
          The 1024 x 576 is listed because it is "Anamorphic" which you can do your own research on. Google is your friend.
          DVD res for the actual display is usually around the 720 x XXX mark.
