Need Help!
    Need Help!
    I'm trying to create a DVD that only has the main movie and the main menu functions. How do I know which files are the menus?
    What version of dvdfab are you using?
      I'm using the latest 6.2.0.5
        first lets set up some settings on dvdfab first okay
          I will take that as a yes! Make sure pathplayer is on. Also what dvd are you having problems with?
            well, what settings?
              If you only want the main movie, why do you need the menus? Just use Main Movie copy mode.
                1. Dvd is in drive. Dvd fab starts up and it asks you what region. hit okay. Then dvd fab reads your dvd. When on main movie ( select on the left side of main screen ) The main movie title will come up ( in the middle part of main screen ) select next on the bottom right.
                  I guess I should rephrase that a little, I meant that I want the main movie with just the title menu (Without all of the extras like special features). That way I can fit it all on a DVD without losing all of it's quality
                    Sorry I also misunderstood. As long as you have selected main movie on the left side of main screen in dvd fab your title shold come up.
                      No can do easily!!!
                      As signals said, why not just do main movie? You can still navigate through chapters, etc, etc.
                        thanks gregiboy and signals. I needed some help here.
                          ahh alright, sounds good! Thanks!
                            Wow that was easy and didn't need any duct tape. Your welcome
                              works for me
