This Notice is to alert you that the Spring Festival (Chinese New Year) Holiday is underway in China and much of Asia and for this reason the DVDFab Office will be closed until February 4. During this period, support by chat and email will not be available but the forum will be here for any problems you may encounter. Purchases of new products and license renewals may be made normally on the DVDFab website. Thanks for your understanding and Happy New Year!
Downloaded 8.1.53 but for the life of me I cannot find DVD Creator & Blu-ray Creator. Are they in 8.1.53 and if so where?
Cheers
Steve
Hallo Steve in the left main menu under the tab "Video Converter" you will find the tabs:
DVD Creator
Blu-ray Creator
Good Luck
Timothy Arens
Reason: Add picture link
Searching for yourself is a lifetime journey.
Life is what happens in between.
An ISO is not a video file, it is a disc image. If you made it with DVDFab it is ready to burn. If you want to change or compress the content, you would use DVD Copy or Blu-ray Copy to open the ISO and re-process it, then burn it.
