Licenses
    License/Key Licenses
    Hi All
    Are you able to reissue the licenses I bought for the windows version for use with the mac version so i can try it out?
    Regards
    Rich
    You don't need a license to trial Fab products and there is no cross-over or temporary license available.
    You have a 30-day free trial for the Mac products to use whenever you wish.
    HTH
      yeah i installed the mac version over a month ago but didn;t get round to using it in earnest - so the bluray ripper option has expired, hence i can't fully test the features i use on my windows machine.
      No options available to me then apart from either buy a new license or keep using the windows version until it expires in 2014?
        You can email Fengtao and/or support directly, but my feeling is you're skunked.
          The Mac trial should be good for 60 days according to the marketing poop.
            Thanks signals...good to know
              I think I saw that in a marketing email so consider the source........
              An email to sunny(at)dvdfab.com might also be a good thing for rgill to try. Sunny can work miracles.
