Wondering if DVDFab will burn a wmv format to DVD? And if so, how do you go about it? Thanks!! Crickkette
WMV?
If you just want to store the wmv files on a DVD, you can use any burning app (e.g. windows, ImgBurn, Nero etc.). DVDFab DVD Creator will convert the wmv files to a format that will play on a DVD player.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
