Posted on another thread here that 8.1.6.8 is the version offered on the download page, but 8.1.6.3 still shows in the forum as the official stable release and 8.1.6.7 is the official beta.
Then I found this at
March 17, 2012
DVDFab 8.1.6.8 Qt Updated!
New: Added support for Windows 8.
New: Updated qt runtime dlls.
New: Updated language files.
New: Added profiles for new iPad and some Android mobile devices.
New: Some minor changes and improvements.
Fix: A problem of drag and drop.
Blu-ray Copy:
New: Added support for new BD+ protection.
New: Added support for new Java-based protection.
New: Added brand new "StealthyClone anti-protection" as a generic way to beat latest Java protection. Please visit to get more details.
New: Added option "Remove Java protection with StealthyClone anti-protection" in "Settings -> Protection -> Blu-ray".
New: Improved main playlist detection for latest Blu-ray discs with fake playlists protection. DVDFab will select correct main playlist with correct angle in "Main Movie" mode, also the main playlist can be got in "Settings -> Info" window.
Fix: A black screen problem when BD-Live is removed, and user accesses the BD-Live content from the backup disc.
Fix: A video stutter problem when copying Blu-ray disc to BD5/BD9 with Intel Quick Sync encoder.
Fix: A freeze problem when copying to BD5/BD9 with GPU acceleration enabled in certain cases.
Fix: A bad quality video problem when using Lightning-Recoding in certain cases.
Fix: Blu-ray 3D backup disc is not playable when using "Copy as Blu-ray 2D" in certain cases.
NOTE: We suggest user to use the original Blu-ray 2D disc to create 2D backup, and use original Blu-ray 3D disc to create 3D backup. For single 3D+2D disc, there is no problem to use "Copy as Blu-ray 2D".
Fix: Blu-ray 3D backup disc is not playable when using "Convert to Blu-ray SBS 3D" in certain cases.
Fix: A 504 error when copying Blu-ray 3D disc to BD5/BD9 using "Convert to Blu-ray SBS 3D" in certain cases.
Video Converter:
New: Added support for ass/ssa subtitle files.
New: Added support for UTF-8 and unicode subtitle files.
DVD Creator:
New: 16:9 output will be selected automatically when source file is wider then 16:9 like 2.35:1.
Blu-ray Creator:
Fix: No sound problem when converting other audio stream to AC3 audio.
March 17, 2012
Blu-ray Copy:
Video Converter:
DVD Creator:
Blu-ray Creator:
