As I said, read the "Registration Key Problems" thread and follow the instructions precisely.
I am sure that it is a problem with the UAC in especially "Home" versions of Windoze but cannot confirm it. The procedures in the thread should circumvent the problem.
like maineman said but the key might not have registered correctly and if you request and try a new key it should work for you. You do not have to buy a new key just request a new one to be sent to you as that is free and would be sent to your email immediately as well
Please read ALL the posts above. The answer to your problem is there !!!
The only resolution I see in the above posts is to request a new key. As I said, if no one knows of an alternative resolution then that's what I will do.
