I just upgraded to the latest version, and now when I open up the settings screen the DB Protection screen is no longer there. How do I enable/diable BD Live? (will attach screenshot)
BD Protection Option Screen gone in 8.1.7.5?
It is still there in mine. Look under the Protection heading. You have a different area highlighted in the nav pane. If you still can't see it, redownload and reinstall v8.1.7.5.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Have you tried the re-install? What is you OS? There is now a newer version than 8175, try that.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
