Sorry if this is wrong place to post my question is that when I insert bd movie into my external :Sony bwu 500s bluray burner in a external enclosure it don't start scanning automatically I have to x out of fab and reopen then it starts scanning automatically with disc init before I open but dvds in my hp dvd drive internal automatically scans is their a setting for this? ???
7.6 scanning movie
Sounds like your operating system is not seeing the external drive until it has some activity, i.e. a disc in it. If you use it exclusively for reading discs, make sure it is on the Drives list with a chckmark in the box in DVDFab Settings.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
DVDFab scans drives that are in the OS when DVDFab is started. Try starting the drive and putting the disc in before you start DVDFab. I had to do it that way on an old laptop I used several years ago with an external BD drive.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Ok ty that always works the only problem with that if it on dvd copy I got to select bluray x out and reopen but it works thought there may b a setting I didn't know about do I need fab virtual drive if im just coping main movie and full disc I don't watch them on compute except on the little player that u can use in dvdfab to view movie be fore u start process thanks for ur time signals...
...Death Before Dishonor...
