Purchasing additional DVDFab Modules??
    License/Key Purchasing additional DVDFab Modules??
    I currently have a lifetime subscription for DVDCopy and Ripper and just picked up a Blu-Ray Writer and wanted to purchase a lifetime subscription to the Blu-Ray Copier and Ripper as well. How do I purchase them so that these new modules are active within my current product? I was thinking that as long as I use my existing Member Email Address it should work fine but wasn't sure and was hoping that one of you have done the same thing....
    TIA,
    Rafterman
    I believe if you log into the members area everything will work out as you expect.
      Hi Rafterman
      You can go here to purchase the bundle DVDFab Blu-Ray Copy + Blu-Ray Ripper
      Don't forget the 20% off coupon code on the top right when checking out.
      The new keys will be sent to you, or you can download them here in the members area
      If you have not been here before use the create an account, you will need to use the e-mail you used when you purchased Fab and a new password.
      Hope this helps
      CBR929
        Most important advice: use the same email address as you did for the earlier purchase.
