Any one else having problems copying Act of Valor
    Hi
    Does anyone else have trouble copying Act of Valor using DVDFab 8.1.8.7, and 8.1.8.5.
    The internal log is listed bellow.
    DVDFab 8.1.8.7 (2012/06/05 13:16:22)
    0m 04.04s: GPUAccelerate: 3
    0m 04.04s: CUDA cap: 0
    0m 04.04s: Support coreavc decode: 0
    0m 04.04s: Graphics info: ATI Radeon HD 4350 : :
    0m 04.22s: Qt Translator file load success
    0m 04.49s: Load config successful.
    0m 04.85s: Init profile data driver sucessful.
    0m 09.61s: Init GPU settings sucessful.
    0m 09.62s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 0 file2dvd 1 file2bluray 1 file2mobile 1 filemover 1
    0m 09.62s: dvd2dvd:dvd2mobile:blu-ray2blu-ray:blu-ray2mobile:blu-ray23d:blu-ray2dvd:file2mobile:file2dvd:file2bluray:
    0m 10.53s: Config ExBar successful.
    0m 10.53s: dvd2dvd have 8 elements.
    0m 10.87s: dvd2mobile have 29 elements.
    0m 12.73s: blu-ray2blu-ray have 4 elements.
    0m 12.79s: blu-ray2mobile have 18 elements.
    0m 13.88s: blu-ray23d have 7 elements.
    0m 14.27s: blu-ray2dvd have 1 elements.
    0m 14.27s: file2mobile have 28 elements.
    0m 15.97s: file2dvd have 1 elements.
    0m 16.02s: file2bluray have 1 elements.
    0m 16.49s: Config work ui controls successful.
    0m 16.94s: Init burn engine successful.
    0m 17.08s: StartNotify successful.
    0m 17.08s: opening drive E
    0m 17.09s: got media type 4
    0m 17.21s: got max lba 2567809
    0m 17.25s: type DVD-VIDEO
    0m 17.25s: volume label ACT_OF_VALOR
    0m 17.64s: got copyright 1 fe
    0m 17.98s: got udf/iso
    0m 19.59s: got discinfo
    0m 19.60s: pathplayer enabled
    0m 47.92s: got dvdinfo
    0m 47.92s: opened dvd
    0m 08.81s: read error: 3 14032 2265185 2068632 0 2 14032
    0m 44.07s: user cancelled
    0m 01.03s: read error: 3 14032 2265185 2068184 0 2 14032
    Read errors are caused by several things.
    Dirty disk.
    Scratched disk.
    Defective disk.
    Dirty drive lazer.
      The disk is new, not scratched and the disc does play in Windows Media PLayer. I will try run a cleaning disc through
        Everything seems to check out, maybe its a defective disk.. But the movie still plays fine in the dvd player and on WMP. I just can not copy it
          Yes the movie plays fine in a DVD or Blu-Ray player. DVD-Fab is unable to decrypt the disc. Using DVD-Fab van even produce a 'not approved administrator' type error message.
          Other DVD copy software can copy this particular DVD or Blu-Ray disc. We have tested different burners & versions of DVD-Fab and achieved the same resulkt which appears as a decryption issue that can result in an Operating System error message albeit it does not stop the PC system operation. From the reports here it would seem DVD-Fab may have an unresolved issue with the protection on these discs.
            You have re-opened a thread that is almost a year old. Please start a new one and post new log files made with a current version of DVDFab.
