What's the deal with getting my DVDFAB DVD Copy program license renewed? I get a validation/verification failure regardless of whether I try a new registration or try the "forgot password" link using the account I purchased the program with. I'm not sure if I get any savings by renewing instead of just buying a new copy anyway. This problem is quite annoying and although I really like the software I'll move on if this can't be resolved soon.
Registration/renewal problems
You get tremendous savings by renewing instead of "re-buying"; a one year renewal of DVD Copy is US$10, buying it is $45. You can renew it for Lifetime for $42, less than it cost to begin with. I just checked a special account I have set up that holds expired licenses and it worked fine. Validation error usually means that you typed the tiny little numbers into the box incorrectly. Please try it again.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Hi Siddus,
Please register at
then you will get an active link in your email, please active to set your password, then you can login in DVDFab user center at to download key, change registered email, renew products, etc.
You need to go to the left navigation tag "Renew Products" to renew your DVDFab products.
If there is still issue for you, please email me at sunny@dvdfab.com
Hope this helps.
Sincerely,
Sunny
Siddus
A new license is much more expensive than renewing, you should send an email to sunny@dvdfab.com and explain the problem.
Hi Sunny, I did not see your post.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
