I updated to 8.2.0.0 and I continue to have the save problem, it takes 40 min just to scan the folder and 4 to 5 hours to do a BD50 to BD25 compression. Using the same movie folder and using 8.1.9.0 the scan time is 3 to 4 min and the compression time for BD50 to BD 25 is 1 hour and 10 min.
Initial Disk Scan...
Try it for yourself. I just tried the new Lorax Blu-ray and it opened in about 1 min 40 seconds with v8.2.0.0. If you have a problem, post in the correct forum (DVD or Blu-ray) and include the internal log for the slow disc.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
No one expects you to, just to post in the correct place and supply an internal log from one of the sessions or possibly the titles of ones that work and ones that are slow.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Start a new thread when you have time to supply additional information.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
