I do not normally update my DVD Fab very often, however now I am as someone suggested I do after purchasing DVD Creator.
I downloaded and installed okay 8198QT and have now just downloaded 8200QT from this forum however it will NOT instal and causes my DVD Fab to NOT work altogether.
Tried it several times with same result.
I have been able to reinstal 8198QT and it is again working perfectly
but NO 8200QT
I have now closed everything, cleaned with CCleaner and restarted my computer.
With nothing else open, checked the download of 8200QT with Malwarebytes and MSE (no problems) then tried to instal 8200QT again with the same result, causes ALL my DVD Fab to NOT work.
Then reinstalling 8198QT and everything is okay.
Okay, this has me stumped, I will wait after this post for a reply from a programmer or someone.
I just tried (which I had not before) to download and instal 8199beta, which installed and worked perfectly.
Then tried 8200 again and NO good, DVD Fab stopped working altogether, HELP............
