Hi, Just finished my first HTPC. Intel based Win 7/64. with XBMC as a front end.
Now I want to build my liabrary on an internal 2TB drive. My Library is small consisting of about 50 movies and 20 concert dvd's and a couple of Blu-ray's
Because of the small size I don't think that I need compression.
For the concerts I would like to maintain full menu functionality and the best in audio and video quality,Does that mean that I need .iso files??
For the movies I'm fine with just the main movie part, .mkv I think??
As you can tell I'm new to this so please excuse my ignorance![Big Grin](https://forum.dvdfab.cn/core/images/smilies/biggrin.png)
So which product do I need to get ?
DVDFab Ripper ?
DVDFab Copy ?
DVDFab encoder?
Is there one product that will do everthing for me??
Thanks...
DVDFab Ripper ?
DVDFab Copy ?
DVDFab encoder?
Thanks...
