Sorry for dumb questions but......
    Blank Media Sorry for dumb questions but......
    I've noted that a good DVD+R DL burn would be @ 2.4x write speed. Now 98% of the time I buy Verbatim brand with AZO feature and can burn @ 8x. Now since Verbatim is the Lexus of the blank media, would it be safe to burn up to 8x (if my burner supports those speeds)? TIA.
    Verbatim makes two different "models" of +R-DL DVD blanks, make sure you have the correct ones for the higher speeds. If your burner firmware supports it, you should try a few at the higher speed to see how they play back. I always burn the high speed ("8X-10X") ones at 6X, they produced better quality scans at that speed than any other (better than 4X or 2.4X).
      Thnaks! mine clearly states "8x speed" and yes my burner supports "6x speed". Thanks again, I'm gonna try "6x speed".
        P.S. could you post the model # of the verbatim you use please? Mine is Verbatim #96542.
          Hi forest.lawn
          Mine are the same as yours and have no problem burning at 8X.
          The 2.4X Verbatim +R DL are rated up to 6X.
          CBR929
