How to make hardcoded subs
    Is it possible to have the subtitles play on a dvd without having to use your remote control to choose them? In other words, to have the subtitles hardcoded/hardsubbed so when the dvd is played, the subtitles are just there automatically. Thank you for any thoughts on this.
    You can do this using Customize or Main Movie mode in DVDFab DVD Copy or using the DVD Ripper module to burn the subtitles into the video when you make a MP4/AVI/MKV etc. file conversion.
    For the DVD Copy modes, select the subtitles you want by putting a check in the box for the correct stream, then click just to the left of the box so that a small arrow or triangle appears. These subtitles will now play automatically whenever you play the DVD with no intervention necessary. You can turn them off using the remote if desired.
      Thanks ever so much. If that does work, it is exactly what I was looking for.
