When I log on to forum pass and e-mail work.When try to use Fab 9 don't recognize e-mail or pass.Why?
DVD Fab9
You need to go to the members site and create an account using the email address you used when you purchased Fab. The forum account will not work.How to post the internal log
Hi reelk
You need to register in the members area first, found here http://www.dvdfab.com/member.htm click create an account.
You must use the same e-mail address that you used when you purchased Fab, and whatever you want for a password.
Upon opening Fab 9 you will use the same e-mail and password you created in members area.
CBR929
Sorry 90312, didn't see you.Even if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
An odd problem, thanks for the feedback. Do you mean when you select the English language version on the website it works?Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
