Cinavia protection on The Campain
    I got about ten minutes in watching my copy of the campaign and a message comes up saying that the audio has ben muted due to cinavia protection. Any one got anything for this?
    Www.cinavia.com message#3
      Get a un infected player
      ...Death Before Dishonor...
        If your backup is a Blu-ray and you're playing it on a PS3 you are out of luck. For other standalone players you can try the Cinavia solution checkbox in Bluray Copy if your drive supports it.
          I am watching a regular DVD not a blu ray. I am watching it on a Samsung blu ray DVD player
            Unfortunately, the std dvd is also cinavia protected.
            Fengtao's list for both BD and std dvds is updated on a regular basis.
            I'm guessing the player & firmware list is also, but it's just a guess since
            I've been using media players pretty much exclusively for over 2 years.
            Scroll down for the respective lists:
              Thanks for the link there. Interesting stuff to read. Iam sure you guys will figure it out. I guess ill just watch it in a different room on a different player. I just updated my dvd player. May try to figure out how to remove the update since alot of the discs on the list i have and worked fine last time I saw them.
