DVDFab v8 registered vs v9
    I'm registered purchaser of DVDFab v8. Am I still registered for the new v9?
    I installed it yesterday and used it as trial OK. I keeps the old v8 on the system as well. Do I have to repurchase version 9?
    No you are licensed for v9 as well at no charge. You do need to create an account at the Member Center on the DVDFab website using the email address that you used to make the original purchase. Then use the email and password you created for the Member Center to register v9. If you already have an account at the Member Center, just use the email and password to register v9. It will coexist with v8 and v8Qt on your PC.
      Excellent Thanks.
        I don't see where to do this registration. All I see to do is :
        Renew Products
        Upgrade Products
        Change Password
        Change E-mail Account
        Newsletter
        Logout
        Thanks
          Hi coolecho
          Please read post #2 again the instructions are there.
          When you install Version 9 a screen will pop up for you to type in the information.
          CBR929
            Hello, I did what you said and it still doens't register!. I even completely deinstalled it reboot and reinstall and when register box comes up I put in the email and password it still comes up trial user. I know I have the correct email and password because I login with that same data when log in to the member center.
              That is strange. You need to have an internet connection to register v9. You also should run the installer using the As Administrator option.
              Any error message?
                Hello, As admin doesn't fix it either. I for sure have internet because I open up the browser to member center and log in there. I posted pics as to what comes up when I put in my registration. I do the sign in and then a licensing window pops up before starting the app. There are no error messages of any kind it just silently goes to the license list window after click register.
Name:	DVDfab Register.jpg
Name:	DVDfab License.jpg
                  Hi coolecho
                  Please e-mail mona@dvdfab.com
                  She will get this straightened out.
                  CBR929
                    Hi coolecho,
                    After you login DVDFab user center can you find any DVDFab products under your account? You need to use the email for the DVDFab purchase to register in DVDFab user center and register DVDFab 9.
                    Any questions, please contact me at mona@dvdfab.com, we will help you out ASAP.
                    Regards,
                    mona
                      You might also need to download your license key and double click on it.
                      Lancool K-56 case.
                      OCZ 700watt PSU.
                      MSI 990FXA-GD65V2 AM3+.
                      AMD 8 core FX-8120 3.1ghz.
                      ZALMAN CNPS9900MAX cooler.
                      16gb G.skill 1600mhz memory.
                      OCZ Agility 120gb SSD.
                      WD 2TB.
                      EVGA GTX Geforce 550Ti.
                      LGWH12LS38 BD-RE
                        OK - I am emailing Mona.
