False alarm update notice
    A few days ago I updated my DVDFab All-In-One to version 9.0.1.6. A few minutes ago I checked for updates and got the notice that there was new version: 9.1.0.7.
    But when I clicked Yes to update I found there was only the 9.0.1.6 version as an update.
    Then I searched here in the forum and knew that there is a 9.0.1.6 version, but it's beta.
    Is that a problem in the program? Or there is somewhere an option to stop it from checking beta versions?
    TIA.
    Not a false alarm: http://forum.dvdfab.com/showthread.php?t=20154
      v8 did not consider a beta to be an update, and did not report them when checking. I guess v9 is different, but you can set it to not check at all for updates in Settings. Personally I think I would rather know there is a new release out there, whether or not it is an Official or a Beta.
