I still have version 4 and 5 hahaha they have come a long way.
When is DVDFab 8 going to be phased out?
Guest
Originally posted by ripvanwinkle1819 View PostThere is no difference between the two versions really as far as what they do. But it comes down to preference. I can see ver 8 being phased out eventually and over time we will all get use to ver 9. Well if you still want to use fab then you probably will not have much choice. Also I can't see it being very economical to the fab team to keep both going.
I prefer to be off line while making DVDs.
Originally posted by davidh View PostWell there is one massive difference in that I understand you must be on line to use, or at least start, using version 9, and I just do not like this idea.
Guys you don't have to be online all the time. In Version 9 be online until the program loads for DVDs and if BR until the disc scan completes then log off the net to work it over. You need not be online 100% of the time.How to post the internal log
Guest
Originally posted by 90312 View PostGuys you don't have to be online all the time. In Version 9 be online until the program loads for DVDs and if BR until the disc scan completes then log off the net to work it over. You need not be online 100% of the time.
Version 9 checks with the server for your registration, and if it is a BR disc it looks to the server for some decryption information, same as version 8 has for a long time now. The only real difference is the initial license check for version 9.How to post the internal log
Guest
Originally posted by 90312 View PostVersion 9 checks with the server for your registration, and if it is a BR disc it looks to the server for some decryption information, same as version 8 has for a long time now. The only real difference is the initial license check for version 9.
Think I will stay with 8 as long as possible.
Originally posted by davidh View PostWell I only have DVDs so IF I upgrade to 9 all that is happening is DVDFab are checking my honesty.
Guest
Originally posted by GregiBoy View PostIt's not your honesty that's in question, it's the other MOFOS that are selling registration keys illegally and the idiots that are sucked in by a cheap price that buy from them!
I could understand if anyone now buying 9, OR any of us long time users want to upgrade to 9, having to go on line ONCE to check us out, but NOT every time I want to use DVDFab.
As I said I think I will stay with 8 as long as possible.
There may be changes to the online feature but, not for Blu-Ray as it needs it to get the keys from the sever.
Only Fengtao can make this decision about being online and I am happy with whatever his decision may be.
Believe it or not there are many programs that connect to the internet with or without your knowledge.
How do you think these programs tell you that there is a newer version available and you have updates? Magic or crystal balls
CBR929Even if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
Guest
Originally posted by CBR929 View PostThere may be changes to the online feature but, not for Blu-Ray as it needs it to get the keys from the sever.
CBR929
Just for me I do not want to have to be on line every time I want to use DVDFab, especially as I only do DVDs not Blurays, so I will stay with 8 as long as possible.
I go to a lot of trouble to try to ensure no sites can access my computer randomly, apart from MSE, Malwarebytes and CCleaner which are (hopefully) protecting my computer.
