I have several old versions still installed on my computer, can or should I uninstall them?
Old versions
Hi is14fun
Most of us keep them.
You never know when an older version might work and a newer version fail.
I try to keep all installers in a separate folder and send them to members via e-mail if they should need them.
CBR929Even if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
No, that is only true if you install a non-Qt version with a Qt version (e.g. v8.0.8.5 + v8.x.x.x Qt) or any v8 with any v9 or if you manually set the install folder to something other than the default. What you may want to keep is the installer exe file, the one that you download.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
It is the environment used to write the code.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Originally posted by Axel Slingerland View PostOk, thanks... I'll remember that. So just out of idle curiosity, what exactly is Qt?Qt (/ˈkjuːt/ "cute", or unofficially as Q-T cue-tee[6][7]) is a cross-platform application framework that is widely used for developing application software with a graphical user interface (GUI) (in which cases Qt is classified as a widget toolkit), and also used for developing non-GUI programs such as command-line tools and consoles for servers.Programmer in Python,Java,JavaScript,Swift,PHP,SQL,C#,C++,Go,R
