when will there be an update for alex cross. I try 8227 but it says you have to renew or buy.
alex cross
It means your license has expired, check it.Originally posted by mugenrs View Postwhen will there be an update for alex cross. I try 8227 but it says you have to renew or buy.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
