DVDFab Upgrade from v9.0.3.2 to v9.0.3.5
    I previously had DVDFab v9.0.3.2 installed on Windows 7 x64 SP1.
    I changed my settings such that...
    - Steams, Subtitle; "Do not select any track" was selected.
    Today, after loading DVDFab, I was informed that v9.0.3.5 was available, so I upgraded.
    After upgrading to v9.0.3.5 this setting was lost and "Select all tracks" was selected.
    I don't know whether other settings were reset back to their defaults - this is just one that I noticed.
    I thought I would mention it, just in case this is a minor bug.
    Kind regards,
    Delta12
    You may need to reset a few others, including unchecking the boxes for any optical or virtual drives that DVDFab should ignore.
      Hi signals,
      Many thanks for your reply.
      Are you therefore implying that this is a bug? One would assume that previous settings should not be reset after an upgrade.
      Delta12
        Today I upgraded from v9.0.3.5 to v9.0.3.6 and in doing so I noticed that the settings have not been reset to their defaults.
        Perhaps this was a bug in an earlier release?!?!
        Anyway, for now at least, case closed!
        Delta12
          It is fixed, it was in 9033 I believe.
            Oh perfect, thanks again!
            Delta12
